If you need something cheap... go for 40W one... and add diode and bypass it with switch. Made one for myself for most jobs 20W does it well, for big joints like speaker cables and large diodes 40W is just perfect. Bought 2m of white copper rod 5mm in dia. Sets in the iron perfecty been loving this iron for 2 years now, lasts very long if diode is between.
Wall plug irons are set high temp to can hold some thermal recovery as they are non regulated by a controller station. The 40W Weller is 450C(!). So that basic switch power control you employed surely helps rough versatility. Most guys have 20-25W plus 40-45W separate irons and many times a soldering gun also. A good station based iron is in another league of course.
I bought a £30 temperature controlled iron from Maplin and it lasted a few days before it packed up.
They replaced it and the next one packed up as well !
So I bought a 30watt Maplin cheapie and that has lasted me about 3 years now. Just replaced the tip a couple of times.
It doesn't care if I leave it on the tip lasts fine.
I would probably advise buying a decent make like a Weller. 30-30 watts should be fine for most jobs.
The minimum you may spend for a station iron with acceptable quality is for a Xytronic LF-1600 at 80W or LF-3000 at 90W IMHO.
http://www.youtube.com/watch?v=Oq-Ubx0Orrk
I get on fine with discrete smd components with a soldering iron.
I don't get on with IC's very well tho I seem to kill most of them.
I have a better hit rate with a temp controlled iron.
I bought a heat gun and that works better with IC's.
The short smd IC legs seem to conduct heat into the IC too well.
I have a controlled heat air gun for shrink wrap and solder paste soldering. The ubiquitous el cheapo ATTEN 858D.
I have the same.
Let us know your experience and hints for using it soon.
Thanks for all the replies
Well started to replace the electrolytic cap in parallel with my woofers, each circle of solder around the caps leg is about 5mm diameter, I started with the 1.5mm tip (beginner I am) after a while decided to try the 5mm spade, I guess after around 10 seconds first leg was free
Not long putting the replacements in, and all went rather smoothly, rather unexpected Only once did I forget to tin the tip.
Speakers work better than before
Much nicer iron to work with than my old one, looking forward to the next little job, makes the hobby much more enjoyable than just a task that needs doing. Especially when I practice and become more confident it will be a wonderful tool to have.
Thanks for all the advice!!
Off to re-watch some some youtube soldering vids.
Cheers
DC
Excellent.Thanks for all the replies
Cheers
DC
AT858d
I have the same tool as well. It was recommended by a friend for its low cost and good performance. Works well and nothing to complain. You can check out a Youtube video review of the soldering tool here EEVblog #167 - Atten 858D Hot Air Rework Review - YouTube , for more spec and features, see this review Best Cheap Hot Air Rework Station AT858D+
I have the same.
- Design & Build
- Equipment & Tools
- Soldering iron what they can and can't do? surface mount, speaker spades ?
