Hello I need help
I'm making an inverter welder
Transformer data:
E 71/33/32 N87
For 50v output
I have 13 primary turns 0.67mm x 20 wires and 8 secondary turns 0.67mm x 58 wires.
The problem is:
The secondary coil I want to wind with copper foil not with copper wires
So how can I calculate how many turns of copper foil I have to make? And dimensions of copper foil? Please help
Transformer data:
E 71/33/32 N87
For 50v output
The problem is:
Exactly the same number of turns as for wire.
Wire CSA is the same regardless of if it is foil or wire.
for secondry i have 0.67mm x 58 wires
what size of foil i use please help i'm not understanding
and thanks for quickly reply in other forums they reply after 1 month
help
for secondry i have 8 turns of 0,67mm x 58 wires
what size of foil have to use please help im not understanding
Please do not use all caps when posting. Read the forum rules, they are here.
I have fixed your post.
sorry
Why do u want to use foil? That is only used in planars where sw-freq is very high, b/c that requires low inductance and few turns. It will likely become very capacitive with that many turns.
i want to make this
Welding inverter 100A
Your secondary wire is 0.67mm in diameter ?
so cross section area (csa) of one strand is pi*d*d/4 = 0.35 mm2, right ?
0.35 mm2 times 58 strands = approx. 20 mm2
so you need at least 20 square mm cross section area of your foil.
Thermal properties of foil may be different, I don't know.
Also, if inverter frequency is high, multiple strands of wire is much better because of skin effect.
you are a genius man thank you very very much
but one other thing i calculated all with this software diysmps
but one thing is not clear if i have to wind for first primary or secondry turns
- Power Supplies
- smps transformer
