SMPS Noise
SMPS
I will post the voltages, but I need is an explanation why the mosfets die quickly.
do I need to put Zener diodes at each secondary output?
Running the supply at 170VAC , will make it survive.
But at 220VAC , problems starts.
And please note that I know exactly what I am doing.
I see two immediate problems with the K6 supply:
No DC blocking cap.
Gate resistors are probably too large (for turnoff) and IRFP450 have huuge Csrss, probably causing shoot-through. You should probably add a diode (or even better a suitable transistor circuit) in parallell with the gate resistors to help discharge the gate and keep the transistors off. Turn-on probably needs to be pretty slow though.
