edl said:
Dear TeeJay,
I've got a working prototype
It costs 150USD.
Regulation is between +/-10%.
The weight is 13kg.
It only uses 1 part (+ a few for soft-start)
Size is 220mm*88mm.
It's called: toroid transformer.
Best regards,
AHHH but for the serious people READ ..... the specs required!!!!
TJ
I think $5000 for a working prototype. A schematic is only 20% of the design. The other 80% consists of designing the PCB, optimizing the design and gathering proof that the device will function correctly under all circumstances.
And there is a huge difference between making a device that kind of works in a hobby situation and making a device of professional quality which obeys all the laws, passes all the tests, is idiot-proof, and can be produced in volume (although the last requirement is not necessary here).
I started designing an inverter for my BS thesis. It is quite a project when you consider everything that you need to do for a good design.
If I had to do this I would consider the following topology first:
1. Rectify input (or use a PFC input stage)
2. If isolation is necessary, use a full bridge or flyback stage to produce +-200vDC --> A flyback would have to have a fairly high VDS rated device, probably an IGBT would be good. If you do a flyback you could combine the PFC and this stage in one.
3. A half bridge output to create the 60Hz AC output
4. A good output filter.
The hard part may be controlling this if you have no experience with DSPs or MCUs. I suppose you could use all analog circuitry but it would be a rat's nest.
- Power Supplies
- SMPS 230 VAC to 115 VAC 800W
