I have for a while a diy 2-way speakers 6,5"+1" , which sound perfectly fine to me.
However, I recently swapped a battery in my DMM, so I decided to check resistance of them for no obvious reason but curiosity.
Measured across speaker terminals one speaker showed 6.8 ohm and the other 7 ohm, is that a difference which requires attention or would you ignore it?
Kind regards
Marko
Kind regards
Marko
Thank you 454Casull and sangram, I can sleep tight tonight unless wife has other plans
Sangram,just to be clear this are the measurements from complete speaker system, from cable binding post via crossover to woofer and tweeter, not drivers individually, which by your explanation would make the difference even more negligible.
Kind regards
Marko
Kind regards
Marko
Thank you guys, I must admit I am partly sad that there is nothing to improve, to tinker with.
Oh, that's entirely different!!
What kind of cap are you using on your tweeter? Muahahaha. Seriously. Tell me or I won't be able to sleep.
Erik
Erik
Hello Erik,
there are two caps in series with the tweeter, one before the parallel coil and one after. The values were pretty high as 15uF and 30uF, that means expensive, so I went with cheap industrial MKP.
Kind regards
Marko
- Small difference is finished speakers Re
