You may also consider the Laterals such as 2SK135 and 2SK1058, different harmonic flavour. As per usual, evaluate both speaker polarities.Hi WBS, that is what I plan to do in the future. I have some quantity of 2SK28s. We can parallel two 2SJ28s.
I am not so knowledged but I think 2SJ28 + IRF240 will do the same work as 2SK82 + IRF9240. If not someone please correct me.
Using the parts (IRF240 9240) from parts drawer seems to be Nelson's DIY philosophy. But I cannot help the curiosity about Lateral FET..
Thank you for the tips, as before.
I realize we are talking VFET and not SIT, but would it be possible to find an N channel Mosfet whose Gate voltage is the mirror image of the 2SJ28 and then reverse the voltage to accomplish a similar result?
Yes, but be prepared for a phase reversal of 2nd harmonic.
Hi Mr. Pass,
is this correct, 2% distortion for 1W for the SIT-3
Not 0.2%?
That was a typo. I thought I corrected that a couple days ago, but
maybe not....
OK, fixed.
SIT-3 play together with " Cube" neodymium wide range drivers ♬♩
Source : 6moons audioreviews: Cube Audio Nenuphar
SIT-3 kit by Nelson..
can be something similar to this? It is the DIY Sony VFet kit that I did not assemble yet. I found that they can be used as DEFiSIT with IRF9240 replacing 2SJ28.![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I tried this front end to my DEFiSIT output stage, and I like the sound, which is different from Firstwatt SIT-3. Maybe the FET regulation circuit could give some advantage?
The bias circuit for 2SJ28 needs to be converted for IRF9240 that needs negative voltage.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- SIT-3
