Hi Alex,
Just ground the section you don't use: grid, anode and cathode.
As to the reason why, I guess I am just not too comfortable to using a tube with one section not being used while the heater is running.
fdegrove said:Hi Alex,
Thanks Frank, I should have stated that, but consider it implicit in my response. If you're <i>really</i> worried about cathode poisoning, and I dont think it's an issue if you swap the tubes, say monthly, then run a high value resistor to the anode to keep a trickle moving through it. maybe 1/20 the active section. Opinions people?
As for elegant, that's certainly up to individual opinion, but I fail to see what's <i>in</i>elegant about this arrangement; you even get your tube pins cleaned regularly.
John,
Sorry if I came across as abit blunt before. Madly typing assignments at 2am.
Toodles
Joined 2009
I hope cdeveza wasn’t waiting 18 years for that reply.
Great retort, made me laugh.
- Tubes / Valves
- Single section equivalent of 6SL7
