Simplistic NJFET RIAA
The ammeter and it's leads/probes are at Mains Voltage.
Dare you risk touching the scale setting buttons?
How do you prevent the probe attachments being touched by other components?
That method increases the areas of potential shock from a piece of double insulated cable to a string of exposed leads and connectors and instument.
Disabled Account
Joined 2012
Warming up
Both boards warming up @ 3.60VDC Bias.
Looking good so far!
Disabled Account
Joined 2012
Kroonsteen
Hi Andrew,
I connect the leads with kroonsteen..... don't know the englisch name for it... see pic. So nothing can touch the leads.
Then, before applying power, I scale the right way. So, if this is done the right way I don't see the danger.... But you are right. Care is very important!
Disabled Account
Joined 2012
After power on the whole afternoon I had to adjust a little.
Rails are now 31.25 and 31.55 VDC. Both TP1 / TP2 are now steady for two hours straight at 3.600 VDC.
I guess it's time to give these parts their home :)
For umbillical cord from Powerbox to Amp box I will use Neutrik 5 pole XLR connectors. I guess that should be fine.
diyAudio Chief Moderator
Joined 2002
Optimal is to buy one more. Now you are using one with secondaries in series for two bridges. I haven't used that configuration I hope it will not hum. People either used one Tx with separate >30V AC secondaries or two Tx with high enough single secondary/double low combined in series, feeding each AC in on the raw PCB separately.
