Simplistic NJFET RIAA
Shunt reg added...
...and it is a keeper! Comparison with the SUT's is very similar; the SUT base sounds less articulate now. Had to lump together some vintage PIO's to get the 3 uF...
I have been playing with VTA to get to a happy place...
The next step is to improve component quality. I might try putting in a bypass cap on the first stage to get a tad more gain.
Electrolytics- Sanyo oscons good? Or Nichicon Muse? A lot of opinions, I'm sure!
Resistors- I've been using the PRP's. Any other recommendations for r-load, etc?
diyAudio Chief Moderator
Joined 2002
You probably mean buffer stage added!:) How many mA you run through the buffer you finally used?
OK, basic things are set sonically by now, and on the right line.
Which model is your cartridge? If you use a bypass capacitor on first stage its going to be +6dB gain. Black Gate there, red non polar 6.3-10V. Or Elna Silmic. Also the RC filters are lending themselves for good 50V electrolytics and they are audible enough there. BG FK maybe. Shinkoh for cartridge load and drain loads, & 43k.
You are determined for top sonics it seems...;)
Joined 2002
Those hi tec resistors are very clean and neutral, excellent components also for noise and ppm, it just depends on where the total system stands by the time they will be tested. If the cartridge and speakers are still rather cold, I would not chose them. If the total mix is already heading to rather warm, I would. Shinkoh for cartridge load and 43k series Riaa resistor I would not change as a favorite though.
Joined 2006
Hi Salas
While I wait for Lee´s work, I have been experimenting with the load resistor in the 101b MM RIAA.
I replaced the stock 47k for a 1k82 and the sound was too shut in.
Then I tried a 464 ohm, and the bass was very tight but lacking body and the stage was confined in the space between the speakers. In this case I noticed a dramatic reduction in output volume.
Finally I tried 27k and the stage widened a lot, the bass loosened a bit but gained fullness and the high freq seems to have a good balance between speed and detail.
The stock MM RIAA has a 1k ohm resistor in series with the signal input (just before the loading resistor and 120pf cap).
I believe this 1k resistor is responsible by the lack of volume when experimenting with 464ohm load, forming a voltage divider.
Would you please explain why there is such a series resistor there and if I can reduce it or remove it ?
Sorry for the off topic but this knowledge will be used when I build the real thing.
Ricardo
Joined 2002
It is probably there to protect from possible instability. Many circuits can be disrupted when enough cable inductance is directly fed to them. Especially loop feedback circuits. In our RIAA there is not such a problem. Even a 100R series resistor that I have used to experiment with early, could be heard to clearly compress the dynamics. It is adding to the cartridge source resistance virtually and reduces the cartridge generator's current output. Off course it also makes for an L pad attenuator in your case too. Yes you can experiment in reducing it step by step in your 101b, even bypass it. If there is a real problem with your cables and the circuit without that resistor or some lower one, it is going to sound like it. If you manage to avoid or reduce that resistor successfully, it is possible that you are going to chose a different optimum Rload than 27k too. In my case the Denon is happy with 1-10k, but this is an overall system balance thing non the less.
Rload is one of those variable hands on things between logical limits.
Joined 2006
Hi Salas
Thanks to your input, I am starting to perfectly understand the several issues related with cart loading.;)
This 1k on series with the signal might be responsible for the compressed sound stage and lo output with 464 ohms loading.
I will follow your instructions and find the best combination.
Additionally, can I modify the 120pF loading cap value without fear ?
What would be the result by just removing it ?
Ricardo
Joined 2002
That capacitor is there for MM cartridges that need it additionally to the cable capacitance so to form a resonance and maintain enough HF output. It is not interacting with MC and Grado carts due to their far lower self inductance VS MM. Since it is not a textbook quality component, better take it out, it may be adding some small residual quality to the subjective mix. Especially if it is ceramic.
Joined 2006
WOW
Hi Salas
This mod was awesome.... thank you so much..:worship:
Now I have 464 ohm Welwyn precision metal film in place of the stock 1k in series.
Adding the benefits of no ceramic in parallel, the 27k RC55Y load seams very good indeed.
There is a lot of detail (less distortion) and attack in the transients and the gain in dynamics is outstanding.
I am already imagining what a direct link could do.....
The strings are now really lifelike.
I really need a jfet riaa.... it will show what the benz can do.
I am amazed.
Ricardo
Salas and nicoch46-
Haven't had a chance to mod more, I've been busy listening to more vinyl...this is addictive!:D I'll probably try the Elna's for all the 'lytics (power and bypass) as the BG's are not in the range I want (and rather pricey).
Why do you recommend a NP for the source bypass?
I might try an AN tant for the load. I'll stick to the PRP's for other R's.
I took my (tired) pre out of the chain and a whole veil has been lifted..surprising! I now hear more subtle changes to VTA, etc. Good solid bass, too. Just can't play it late as it's plenty loud... :D Need to build one of those lightspeed attenuators next.
Joined 2002
You see? You did well in the end. Happy for you.
I find the BG NP open and nice there, that is why I recommended them. But it is always a total system fine tuning thing. It may go contrary to something easily. It is a bit like cooking. You better have a gamut of good ingredients and apply by experiment. But you mention it is loud enough already. Are you sure that you need the extra gain? If not, better avoid, because best cap is no cap.
Salas, i owe You a cold one :drink:
Thanks a lot for the friendly push. After our little "talk" yesterday i couldn't resist trying again, and now i have a nice shunt working.
It draws >250mA, and only gives 22.5 volts, but i noticed my 12V zener actually opened at 11.2V, so i guess it's not too far off.
Again, thanks a lot for sharing this with us. Now i can move on to the RIAA :D
half way ,
if we put a small panasonic resistor with some induttance, similar in Pass design ??
PS photo are only for +/- PSU ,for NJFET RIAA we need only HALF
fist pic are inductive psu, coil hammond 159s 22€(remenber x0,9 not 1,41)
