Simplistic MosFET HV Shunt Regs
Joined 2011
holliday fun
Impressive reading, 2,4 k posts on one subject is what I need to melt all the holliday food:up:
I have som 26s at home, waiting for justification, hence I just did some Mousering/ebaying so maybe i can contribute to break the 3 k wall. Kudos, Salas, V-George and all:wiz:.
Tea-Bag, maybe a stereoversion w one mirrored?
Best regards and a happy 2012!
Staffan
Joined 2009
P2P old tx perfect & solid as a rock:D:):hug::xmasman::wave2::blush::up::spin::king::snowman2::snowman::djinn::superman::santa3::checked::violin::joker::santa::hbeat::Piano::wiz::happy2::sax::eguitar::happy1::clown::hypno2::nod::cheerful::cheers::xmastree::santa2:
HAPPY NEW YEAR 2012
Maybe you have a 10-15mA application for the nice small one you built? Its a nice looking board. Happy new year to you and to everybody.:)
Hi Salas
Before there is GB for SSHV2, I would like to modify my SSHV1 for my phono pre with large hintsink for the MOSFET. Can you suggest which component(s) should be change for my application (300V 55+20mA)? Thanks.
diyAudio Chief Moderator
Joined 2002
You have to lower R1 until the voltage across it divided by its value is going to indicate ~70mA. Before that you will have to change your IRF840 heatsink to 2C/W type, your 9610 sink to 4W/C type. Also your 2SK147 fet due to high transcoductance ~40mS is more prone to drift in that hot environment. Try to put a 2SK117GR or 2SK170BL in its place.
Thanks Salas. Will do the modification in this week and let you know the result.
