Simplistic MosFET HV Shunt Regs
diyAudio Chief Moderator
Joined 2002
Hi, need replacement for KSA1381, and find locally a BD140. I checked the voltages present, are around 40v there in a healty ksa1381 (reg. set at 80V.) So this 80V. PNP may work if there is no other concern?
Jordi
BD140 could possibly prove workable in your relatively low voltage application when you can't find the original but its not equivalent in spec. Although I did not have the need to try it so to say if and how it works in this circuit for sure. Yes the Q4 Q5 PNP cascode is calculated to divide the voltage at about half for even dissipation. As you have measured in your build. The 2SA(KSA)1381 is not only sure to work, its also a significantly better spec part than the BD series (Philips grey color old issue was faster than modern shiny black BD but still no comparison to 1381's linearity) so stick to it if possible if not only for practical concerns but for quality reasons too.
I've been optimizing the SSHV2 for my load. BSP129 as Q2 wants an R load of 122R. Slight higher value than 100R intended for DN2540. 100R is suitable also for IXTP01N100. R6 1,8R is turned to be very imporant to sound quality performance, I ended up replacing for a hand made NiCR resistance wire of value 1,7R which seems to be best value for me. R7 100R works, but on some IRF840 samples sound better 103R, which I find very disturbing. I have bought already a dedicated tester for transistors, but I am afraid no matter, further optimisations again on an empirical way.
Is been difficult setting the choke value on the rough DC side. Choke don't let variable adjustement like a pot. I have used a 10 Henry between the capacitors. Then I calculated trough formula 86V (B+) / 0,145mA (load consumption) = 593 / 1000 ( 50Hz AC mains) = 0,593H.
Being suspectingly low I picked my lower choke value is 2H, a resin potted Bartolucci, that proved going this low, removes bass and midrange frequencies. Otherwise going up above 10H. has proven to be very succesful, as two 10H in series (20H) turned to be much better balanced than 10H.
Only a bit less high frequencies extension than 10H, so I may guess the correct value must be between 15H and 20H.
Is there any other formula available, that prevent buying expensive chokes at glance?
Joined 2009
Why you doubt the information I gave you in private????
Also you don't like simulators because is a lot of work....
Use your methode to put & listen if you don't believe in formulas, there is no different formulas to acomodate your taste.
