Not sure what you mean by shutting down the regulator during the measurement. If I switch off the supply power the output trace disappears even though the scope is in AC mode and you have to wait until it stabilizes again. Anyhow, the SNR is worse with switched off supply power.
It disappears due to the transient until the scope's input coupling capacitor (in circuit when AC mode) recovers after DC is gone.
So by result there is nothing more that the regulator itself adds in the measurement loop given the noise floor resolution it can be achieved. The regulator under test looks properly done then.
Salas could I use this heatsink for DN2540?
Compre Disipadores Disipador TO220 TO247 Clipmount 8K/W Fischer Elektronik SK 480/84 SA en RS Online y lo recibir en 24 horas.
Looks proper sized enough.
For the #26 preamp how much ºC/W will be enough for Q3 IRF840?
2ºC/W
This one will be not be enough, right Salas?
Compre Disipadores Disipador de calor,TO220 3.5degC/W AAVID THERMALLOY KL-100-B en RS Online y lo recibir en 24 horas.
No. Better this: Compre Disipadores Heatsink 2K/W 60x60x16mm anodised Thermo Electric Devices TDEX6015/TH en RS Online y lo recibir en 24 horas.
Salas in place of IRF840 could I use SIHP8N50D-GE3 - VISHAY SILICONIX - MOSFET, N-CH, 500V, 8.7A, TO-220AB | Farnell element14 España?
- Power Supplies
- Simplistic MosFET HV Shunt Regs
