Could be the 1uF capacitor in the Jung mod slows the start up and leaves Q5 exposed to over voltage. Jung did not try or recommend for HV or in combination with a parallel thing so its not a general fault. Make that capacitor 10nF film. See if it may work in a final attempt since you like so much to try that mod in HV.
Doesn't work with real load, when powered Vout was 320V, tried to adjust with the trimmer but when arrived to 290V aprox dropped to 16V, tried to go up with the trimmer but Vout doesn't go up. Powered off and after 10 minutes powered again, same story Vout 320V tryign to adjust 16V, I taked off the two 10R of my CRCR PSU if wasn't enough curren but the issue continue.
- Power Supplies
- Simplistic MosFET HV Shunt Regs
