Re: Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs)
Anybody who knows how the author came to this conclusion? Outperformed by a simple zener? In cost maybe
hemrmanv, Q3-Q5 is involved with their Vbe togehter with a cosntant current through R10. One way for you to find out is to simulate. Have you done that.
hollowman said:In the Feb 2008 issue of AudioXpress (US print magazine) pp. 30-37, the article "Shunt or Not" by author Are Waagbo presents two "sophisticated shunt regulator version":
The author claims that in comparison to his shunts, the JSR03/05 was “a waste of money” (noting a simple zener shunt was better). He also indicates other series-regulator designs (e.g., Borbely and Sulzer) are not much better.
Along with his own, Waagbo does credit Borbely’s shunt regs.
What do you folks think? Can a simple Zener-resistor-capacitor shunt reg. outperform JSR or Sulzer. If so, then the more-sophisticated shunts (above) must be really spectacular – or are they?
Thx for any feedback you can provide.
Re: Re: Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other serie
If you relay on Vbe of Q3, Q4 and Q5 output V will vary from unit to unit and with temperature. Tempco is a minimum of 18mV/deg C or .18V for a 10C change, likely much larger. Unit to unit variations will be effected by both Beta and Rbe.
It might indeed simulate well, but IMHO it's a bad design at least in the sense that's output V is not predictable. In simulators all transistors of a given type are identical and often ideal.
If you build one and it works, that's fine, I wouldn't recommend you make a hundred or a thousand of them.
Circuits build around a TL431 for example are easy to scale for voltage and current. A little work is needed to make them stable (very high gain), but after that each will perform nearly identically.
TI shunt (pdf)
No I haven't simulated the design. If Q4 is the variable shunt element, then current through R8 will vary and so will current through R10.peranders said:
TI shunt (pdf)
I have found the articleAnybody who knows how the author came to this conclusion? Outperformed by a simple zener? In cost maybe
http://www.borbelyaudio.com/pics/waagbo2863.pdf
Personally I prefer when Walt Jung, Jan Didden or someone else write with some technical approach because somewhere you start with technical issues.
If I read the article:
LM317 as preregulators compresses the music.
A super regulator is no good
A plain zener is really good
A Borbely series regulator is also not particularly good
A Borbely shunt regulator is "toppen".
Quote from the article:
It hard to argue about personal taste.I made a simple zener shunt
from some old zeners I had, and it was
not bad at all. While it was noisy, there
was something different about the musical
presentation, which I thought was
positive.
So what is the conclusion of this article? I don't know decides he likes Erno's stuff which I also don't mind because it's good engineering.
My personal thought here is what would the result have been if Mr. Waagbø didn't know what he was listning to? I'm pretty convinced that there had been a totally different article.
Hello again,
Attached the schematic of the regulator i'm testing/listening to.
You must try different zener/diode combinations to get the output voltage you need. Please also test it with the current you need because there is no feedback and the voltage get's a bit lower when the current raise.
The mostfetfolower is a la Charles Hansen's Ayre V3 if i'm right.
Personally i like Mundorf Suprime cap's but they are not cheap and small. The northcreek cap's are new for me. The price is better than the Mundorfs. For sure when the dollar is low and the euro high. But shipping cost...
I do not prefer any particular brand/type of Zener. When i buy some in the shop at the corner it's always a supprise what you get.
Gr.
Johan
hey joho, I know it has been a few years since you came up with this circuit but do you think it would do any good to power a PCM2704 usb DAC? It requires a 5V supply that can normally be pulled from the usb port on the computer but they are far from pretty in terms of noise and tonal quality, and a 7805 is not much better really. The DAC also varies in current draw from idle when unplugged to active when plugged in to the usb.
I tried fooling with this circuit a bit but the voltage would not stay consistent due to loading and unloading of current draw from the dac but it is apparently very quiet...
Simple Voltage Regulators Part 1: Noise
