Simple question...
Hi ya all,
Please take a look at the attached image. This is the output stage of my preamplifier. I'm wonderig, which one of those two transistors (Q17, Q18) should I mount on the heatsink of output trannies. My guess is Q17, but I'm not sure. What will happen if I mount both trannies on the heatsink? Better or worse regulation (not that it really matters in this case since this is a preamp, not a power amp, but I want to make it right)?
Thanks in advance!
Administrator
Joined 2004
small pcb
Hi Quattor,
Why not either plan to mount both. You can pull one away if you end up with a negative temperature coefficient. The other method would be to use a small pcb for you bias and mount it higher up. Circuit changes would be even easier then.
-Chris
Peranders - I didn't want to mess up with the original design that much. It performed so well on the simulator that I just had to built it the way it was given. Anyway, stripping it to one transistor is not that hard once I've sorted this one out :)...
Thanks guys!
