AndrewT said:Hi Luix,
am I reading your layout correctly, the Zener goes from Driver emitter to Output rail?
Is this the best place for it? A genuine question not a comment.
The zener (in that position) prevent gate-source breakdown.
Here's the Vgs Multiplier which was described in the Thagaard/Pass A75 article -- it's pretty difficult to see the values from that which appeared in the TAA article of 1992:
The rule of thumb I always heard was to use the same sort of device for bias that you do for the ouputs. Yes, yes, yes, there are scads of counterexamples, but if you use the same sort of device, they will tend to behave similarly thermally.
I once started to ask Nelson a question about bias circuit impedances, but did not phrase myself clearly and he answered something along these same lines. I never got around to rephrasing the original question and now I've forgotten what it was.
Oh, well.
Grey
Oh, well.
Grey
Thanx to all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Now I've installed two fan, the temperature of the heatsink is very low!!! I can't immagine so low with only two 12V fan!!!
Some photos
http://xoomer.alice.it/luixssj3/index/v1.jpg
http://xoomer.alice.it/luixssj3/index/v2.jpg
http://xoomer.alice.it/luixssj3/index/v3.jpg
http://xoomer.alice.it/luixssj3/index/v4.jpg
Some photos
luixssj3 said:
I have some trouble with it, the Vbe multiplier is oversensitive, if I set the bias (100mA per MOSFET) this slowly decrease as themperature increase and if I rebias at 100mA when the amp restart at cool the bias is over 100mA and I risk some thermal runaway....
Now I set the bias at 70mA ad is OK for the start, no runaway but after the heatsink is hot the bias get 50mA or less...
In your experience is happened thing like this?
Is there any solution?
Sorry for my bad english and thanx in advance...
bye
Are you sure you have to worry?
Are you going to listen to the music, or to measure the bias?
I think, no difference in sound between 10 MA and 100 MA, right?
- Simple MOSFET amp problem
