Ok, flame me if you will, but I don't want to punch the wrong size of holes in my nice shiny copper plate.
I want punch two hole sizes, and thought it would be nice to do it myself.
One is for a simple 9 pin socket (for ecc88, ecc83, ecc82, etc..). I estimate the hole should be 22mm in diameter (that is about 7/8 of an inch for those in some english speaking countries).
The other is for a regular 8 pin socket (for el34). I estimate that the hole should be about 27-28mm in diameters or about 1 1/4 inches.
I was looking this up and read somewhere that those greenlee punches don't actually make the same size hole that is written on them...
I don't know if this is true, but it would sure be a help if someone could enlighten me on this. Does a 7/8 inch punch make a 7/8 inch diameter hole???
Any suggestions would be welcome. And yes I searched a bit on this and didn't find a thread that addressed this topic well enough.
I haven't mic'd the holes, but I can tell you for sure that the 3/4" Greenlee punch will accommodate 99.9% of the nine pin minature sockets out there. The 1-1/8" works for every octal socket I've used. For perspective, I've had these punches for more than thirty years and they've been used for a pretty good variety of sockets.
SY said:I haven't mic'd the holes, but I can tell you for sure that the 3/4" Greenlee punch will accommodate 99.9% of the nine pin minature sockets out there. The 1-1/8" works for every octal socket I've used. For perspective, I've had these punches for more than thirty years and they've been used for a pretty good variety of sockets.
and a rat-tail file will fix the other 0.1%
"those greenlee punches don't actually make the same size hole that is written on them..."
I believe the confusion on hole sizes originates in the difference between radio "chassis" punches and electrical "conduit" pipe punches. Chassis punches are marked by the actual hole size while conduit punches are marked by the pipe ID size.
Since "conduit" punches are much more common on places like Epay, one should be careful to check.
Conduit punches:
1/2 inch pipe punch-- > 7/8 inch hole
3/4 inch pipe punch -> 1.115 inch hole or approx. 1 3/32 inch hole
1 inch pipe punch -> 1.362 inch hole or approx. 1 3/8 inch hole
Don
Conduit punches:
Don
Use a 1 1/8" (28.6mm) punch for:
American 4-pin (28.8mm)
British 4 pin (28.3mm)
McMurdo Octal (28mm)
Use a 1 1/16" (27mm) for:
PTFE Loctal (26.8mm)
Use a 21mm punch for Chinese Novals.
Use a 3/4" (19.05mm) for traditional Novals (18.5mm)
Use a 5/8" (15.9mm) for DIN sockets and B7G sockets (15.6mm).
A well-greased good quality chassis punch produces an excellent hole; Q-max in the UK, Greenlee in North America. Oh, and if you punch through a piece of thin dense cardboard on the face side of your copper plate (cardboard between the plate and the receptacle of the punch), you won't get any marks on the face.
Umm, Greenlee has two lines of punches:
Conduit Punches which are sized to the conduit fittings they are meant to be used with, and the holes punched are larger than the stated punch size.
Radio or Chassis Punches which punch holes of exactly the stated size.
You just need to know which you are buying.
Mine are all radio punches and holes punched are very close to the stated size.
I use 7/8" or 3/4" radio punches for 9 pin sockets, and 1 1/8" or 1 1/4" for most octal and UX4 type sockets.
Look at smoking-amp' s post for conduit punch sizes.
I have lots of Greenlees and love 'em, but there are cheaper alternatives for light duty use.
Note that there is a company in the UK that makes nice "radio chassis' punches for a fraction of what the Greenlee cost. Sescom normally carries these, but seems to be out of stock. I don't know the brand name off the top of my head, but I have some and they are quite nice.
Ocean State Electronics sells a small radio chassis punch kit which is decent for light usage. (Aluminum chassis) I have one that has served me well for about 15yrs, almost worn out now, going to buy another set: http://www.oselectronics.com/ose_p64.htm
kevinkr said:Note that there is a company in the UK that makes nice "radio chassis' punches for a fraction of what the Greenlee cost.
Q-max. (No connection.)
vax9000 said:HomeDepot has those Greenlee punches. It may not be listed on the webpages, but you can find them in your local store. Then you can take a close look of the size v.s. the label.
vax, 9000
The punches at Home Depot and Lowes are definately CONDUIT PUNCHES.
375 said:I...A hole saw will be the exact size, but can discolor the surrounding area if not careful.
I have been using a 7/8" step drill for nine pin sockets and a 1 1/8" hole saw for octals. The trick is not to use too high a drill speed. A little cutting oil doesn't hurt either.
I found that the blu-mol bimetal hole saws work great and stay sharp. I have them in sizes from 1 1/8" to 2 1/2" and have used them on everything from Hammond steel and aluminum chassis boxes, to 1/8" thick aluminum plate.
Great timing on this thread, as I am just about to put holes in my new chassis. I bought 20 gauge steel (17 x 12 inches). I have octal tubes and sockets that are around an inch diameter.
Someone told me that on such "thin" steel, hole punches can bend the metal. Is this likely to be true? Of course, I can easily invest in a hole saw of around this diameter, and drill slowly with a little oil.
Thanks,
Charlie
Thanks,
Charlie
I have been punching holes up to 1-3/32 inch with the cheap Harbor-Freight conduit punches in thin steel bake pans without any bending problems.
Looking at the punch set, the clearance between the punch and die looks close up to the 1-3/8 hole size, but the 1.7 inch hole size has a noticeably larger clearance and would no doubt cause bending problems with thin material.
Looking at the Greenlee punches, I see close clearance up to 1- 3/8 inch size too. Don't have the bigger Greenlees here to check.
Probably will depend on the brand of punches and size of hole, with bigger holes more likely to cause bending problems. Older, used punches with dull punch edges, will be more likely to have bending problems too.
Don
Don
here's what i use
http://www.oselectronics.com/ose_p64.htm - i thought i paid a little less a few years ago, but still cheaper than a set of greenlees. These punches match up with most sockets (octal, 7 pin, 9 pin, 5 pin etc) that i've needed to use, as an occasional weekend warrior..
I'm considering a set of step drills sometime in the future, now that they're somewhat cheaper than a few years ago.
- Tubes / Valves
- Silly Chassis Punch Question...
