Siliconray Forum
Hey, Ray...The 6V6 Pre-Amp kit is Really Sweet..Where else can you get a Tube Pre for $128? I just put a Remote Alps/ Input in mine..Too bad that they sent me the Wrong Remote for it...But, it still works Manually, Twisting the Knobs for the Vol. and Input, and it Sounds Great...If I ever get lucky enough to find the Remote that Works with This, I'll post the Pics..
Unless, maybe You Know the Remote that will Work with This?
attachment.php
Whoa,...Let me take that back...It Does Work. I had to relocate the Sensor, and doing so I took it too easy on soldering one of it's Leads. I then covered it with Shrink...Having found and fixed that, it now works Fine, even tho the Remote is not the same as Others used for this.
