Inductors
I'm wondering if this inductor is good for this design:
1mH, 240mA, 2.7ohm
LHL08TB102J Taiyo Yuden | Mouser
1mH, 240mA, 2.7ohm
1mH, 240mA, 2.7ohm
From Mouser, this is closest to the one I've been using:
FB20010-3B-RC J.W. Miller | Mouser
Dear Jussi,
First of all, thank you for making the DSC1 project public. Really cool to have people developing interesting projects and making them available to all of us.
I´m ready to have a go at this project but, as requested by other members, we´d love to know if you´re still working on a DSC2 before committing to a DSC1 build!
Could you give us a hint of the states of affairs? We´d really appreciate...
Thank you!
Thank you!
Yes, I'm also working on DSC2, but it is proceeding very slowly since I prioritize any software work above the hardware work.
I've been looking for component selections for the most critical conversion parts. Not easy to find the best one that would also keep the cost reasonable...
Jussi, forget opamp, try discete IV with UHF Transistor Arrays. Take a look at intersil HFA3xxx series.Yes, I'm also working on DSC2, but it is proceeding very slowly since I prioritize any software work above the hardware work.
cheers
China's implementation of open hardware Signalyst DSC1 from Ultimate current, looks better than the original , but do not know how it sounds.
DSC1 DAC DSD Amanero XMOS
This looks like the power supply board.
DSC1 DSD Powersupply
Another Kit DSC1 Kit
DSC1 Kit
cheers
Or a variant of the EUVL Sen I-V (very low noise) with commonly available BF862 JFets: http://www.diyaudio.com/forums/digi...inimalistic-iv-converter-182.html#post4633856
amaizing
https://2.taobao.com/item.htm?id=523327606726
Very interesting, thanks. Chinese electronic engineers the opportunity to revolutionize the native DSD playback - Signalyst DSC1 r2r nos DAC, only 230$
They also try to use hardware SRC converting PCM to DSD using AK4137 chip for universal playback DSC1 DAC (PCM and DSD) without software, meant Foobar2000,HQPlayer ...
AK4137 in DSC1
AK4137 in DSC1
cheers
+1 , I dismissed this board due to the use of opamps.
Operational amplifiers are not so bad, it all depends on the implementation and design. A High-Fidelity Headphone Amplifier for Current Output Audio DACs Reference Design - TIPD177 - TI Tool Folder
Boards arrived:
The parts are inexpensive -- majority of cost are the Susumo RG series 15k 0.05% 10ppm resistors.
Both boards are SMD double sided, the first mostly bypass caps and the chokes that filter each chip. The mirrored version obviously has chips on both sides.
Its going to take some time for me to build, get all the components together to test, needing to build the I-V (sen variant bf862/j111 cascode) and SK filters (jfet buffer based) as well as Salas reflektor-d supplies for digital side, NiCad battery suppies for I-V etc.
For reference, the schematics used:
Clock path optimized:
Mirrored:
Hi Jborden,
is it some progress with this PCB?
OPAs etc.
I have never heard a DAC I/V stage using IC opamps which was not bettered by a really good discrete design. But, I am not sure that is what is going on with Jussi's design. I suspect he may be needing to use ICs as high speed switching devices to drive the digital DSD signal. Then the following stage would be the output buffer, and that could be discrete or IC based...
For high speed, on/off switching, a really, really fast IC is going to be the way to go.
Hi Jborden,
I've been really swamped at work and with kids activities on weekend -- my son does travel hockey and while I can lots of design etc on my laptop in various hotels, hasn't led itself to working much in my shop That said when I get a break from work I am all set to sit down and place all those little SMD parts and then cook the board.
The idea about cascoding the jFets (cascoded SEN with bf862/j111) should minimize the Miller effect/improve bandwidth. EUVL alluded to that. That said, since we are then going to LPF the output having a higher input capacitance may actually be a blessing as noted by Pass.
I'm getting interested in building a Signalyst DSC1 but where to get a board; I don't really want to shell out $160 for three boards from OHSpark.
Has anyone used one of these Chinese boards?
And how do you actually buy one anyway?
I have some excellent low noise regulated supplies and would look to repurpose them if I were to go ahead so only need the DAC board.
- Digital Line Level
- Signalyst DSC1
