Most of my CDP's have output impedances around 1k, so that's what I work with.
My passive pre is a shunt type, with a 100k pot and 10k series resistance. With the primary impedance of 14.7k, reflected from the 367k secondary load, the CDP will see impedances from 10k to 22.8k, satisfying the 1:10 ratio at all times.
Forget it.
It's not just what the CDP will see, but what the CMMI-5C will see driving its primary.
You don't want to feed the CMMI-5C with a 1k source impedance, let alone 11k which would be the best case scenario with your shunt attenuator.
I wouldn't recommend driving the CMMI-5C with more than a few HUNDRED ohms.
So unless you can add an active buffer between the output of your passive pre and the CMMI-5C, I'd find something else to use them for.
se
Forget it.
se
I was simply explaining that from the CDP's point of view, everything's just dandy.
But I did not look that what the transfo "wants" to see at it's input correctly. The series resistance in the passive pre should be eliminated and the source's output R and C checked for LF roll-off. R could be diminished to ~220ohm and C augmented enough for a LF -3dB point sub-20Hz. I should check what is the lowest impedance the output op-amp in the source can safely drive and set that as R I suppose, as I will now be shorting the output to ground when volume is fully turned down.
IG
