I would say between $150 & $200. I sell them to dealers at that level.What would be a fair price for a good condition HP 209A ?
The Hewlett-Packard is a commercial instrument made in America. GAG is South East Asia. The 209A has a low distortion mode switch on the rear panel for low frequency sine waves (audio) that's down near .05% measured, and will provide sine and square waves concurrently at the standard 600 ohm impedance. Flatness is ±0.5% over the audio range.
Not at the moment.Hollowstate,
Do you have a HP 209A for sale ?
Just to make sure I understand right.
The computer option has very low distortion, much lower than the function generator.
Is this true only in sine wave ?
The function generator generates square waves much better than the computer option.
You're right. This is the 5kHz square wave generated by my sound card
What do you guys think of this Leader LAG-120B on ebay:
LEADER LAG-120B AUDIO GENERATOR | eBay
What are some potential problems with this unit and how likely ?
haha, that's not square at all.
Ringing (not that much as in #33) is inherent in digital synthesis. The DDS instrumentation ones do filter the ringing but they lack in rise time as you push them higher to their limit VS analogue ones due to LPF. Talking under 500$. Full rise time is still available on their TTL output which is not filtered and you will be able to see the inherent ringing. Very good stability in PPM over the years and great functionality is the other side of the coin. Very good signal quality is offered by TTI-Thandar made in UK in medium to low prices (relatively, as generators go), they do good analogue still.
If using soundcard FFT for THD which is great for that, there are many cheap enough good solutions for nicely shaped square waves up to 1MHz from instruments that go to 3 or 5MHz. Their THD won't be better than -50dB though.
I picked one up cheap on ebay.
Has worked well for 5 years now.
You mean the Leader LAG-120B ?
Leader is OK, Made in Japan, but is probably the best if the Asian imports. I've never owned one, but I have had some of their other stuff.Hollowstage,
Could you tell me more about the Leader models that you mentioned.
Seems like the Leader LAG-120B is comparable to the HP 209A.
- Design & Build
- Equipment & Tools
- Signal Generator: Which one to buy ? What to look for in a signal generator ?
