Shunt regulator for a phono pre
diyAudio Senior Member
Joined 2002
Would you like to offer a reason why?
Well, I can only try.
The lesser electrolytic caps tend to filter out mainsborne crud, rectifer noise and what have you far more effectively than a filmcap would in a typical CRC filter.
On the same topic, does anyone use capacitance multipliers for their circuits?
While these are limited in use due to max. transistor dissipation, I find them very useful, even in valve PSUs.
Moreover, they don't cost much to cobble up and try out.
Lately, I've been fiddling with one for a tube preamp, using a //ed ECC81 and I'm really smitten with the results.
Cheers,;)
Surely isn't the filtering effect totally dependant upon source R and the resultant cap Z?
I see no reason why a film cap should be worse than a 'lytic of the same value.
I'm puzzled...
Andy.
Joined 2002
Where a filmcap is too good in this application is in DA.
If we'd use regular, off the shelf caps their " poor properties" can be put to good use to help suppress RFI.
I'm not saying they'll do everything you've ever dreamt of but they smooth these critters out better than a filmcap would in that position.
Neither am I saying that you can't use filmcaps in a PSU but if you're going to use regulators anyway, I see no point.
After all, all you need is a clean supply and good PSRR from the reg and whatever sits in front shouldn't leave its sonic fingerprint.
Any opinion on the cap multiplier?
Cheers,;)
