Tube lot update.
The $75.00 is for pick up only. If I have to ship, I can’t let them go for that, ship price $100.00 ($.38 a tube). There are 210 common audio tubes, of that 158 are signal, 18 rectifiers, 18 output and 16 mixed audio use. The rest are mixed use tubes. Some new in boxes, some in random boxes, and the remainder will be packaged in bubble bags. If I have to sell singles, I will, but prefer to sell as lot…and you get a better deal. See Tube_List.pdf above for details.
PassFan,
Actually I have a list of op amps I was trying to get rid of...so maybe you confused me with someone else? I would consider other trades. What else do you have? I'm looking for a decent set of SE OPTs for 300b?
Sold
MCM speakers/set.
I don't have a pair but I do have a hammond 125ESE I was about to put up on the AX84 site. It's been used sparingly in a guitar amp that wasn't my main for about 4 months and is in great shape. Has about 4 to 6 inches of lead left. It's 15 watts 80 ma 10k, 5k, 2.5k .
New Sale prices!
SPKS
Fostex FE167e in Fostex recommended BR box, very good sounding (see Fostex for design). FE167e original un-modified. Maybe 10 hrs use. $200.00. Small enough for shipping but I will have to remove sand filled pedestal/base and ship without sand. Drivers only $120.00 pr (I have original boxes).
You have a PM.
Doug
It's been a while, so I thought I would repost items I still have
Cables
Monster Cable Interlink 100, cable only
8” pr $16.00
11” pr $22.00
Monster Cable SV1 75 ohm, cable only
9” pr $9.00
12” pr $24.00
Distech Silver Plus Interconnect, 3’ pr $50.00
DIY copper foil/Teflon flat speaker cable, 6’ pr $50.00
SPK Stuff
12mh air coils pr $15.00
3.5mh air coil pr $10.00
16 ohm 50W rheostat pr $15.00
Audax DW50m Tweeter w/wedge mount, 4 ohm 94db. $25.00pr w/mount, $15.00 w/o
Blaupunkt P652c 2 way coax 6.5” 4 ohm, 91db 65 to 20Khz 40W NIB $20.00
EV FS-1950 spider for 15” $5.00
EV VC-9200 voice coil for 15” $5.00
EV SR-15 basket gaskets pr $2.00
EV DC7172 dust caps 2.75” $1.00 ea or 10 for $8.00
Waldom AA-78 spk cement 1QT NIB (can) $10.00
Waldom AA-76 spk cement 1 QT NIB (can) $10.00
SS Parts
NTE 2382 Pwr Mosfet, 100V 10A $2.50ea (have 50, deals on multi over 10)
NTE2383 Pwr Mosfet, 100V 10A $4.50ea (have 50, deals on multi over 10)
Power Tech MT1302AL NPN 100V 300A (500A peak), 400W @100c (650W @25c), hfe 40, matched pr. These
Wholesale at $1200, make offer.
Transistor lot of 300 (includes 100 PN2222 and 100 PN2907) $75.00 See post #19 for pdf file.
ICs
AD711an $3.00ea (4)
AD712an $4.00ea (3)
AD744an $4.00ea (4)
AD797an $15.00ea (4)
AD811an $5.00ea (4)
AD828an $3.00
MPC SM5813 $15.00
OP176 $3.00ea (2)
OP275 $3.00ea (2)
PCM56p $10.00
SAA7210p $15.00
SAA7220p $15.00
SSM 2141p $3.00
SSM 2142p $3.00
TDA5709 $5.00
Parts
Daven 18520-PH-51-20(NY) Shorting selector switch, 17 position, silver/nickel. High quality vintage switch built
in 1952. NIB in foil sealed box. 6 to sell $10.00ea or two for $18.00
TT Items
AR Aluminum/foam sandwich arm board $5.00
Uncut Aluminum/foam sandwich for arm boards, 6” X 6” $10.00
Aluminum 3-point cartridge coupler $10.00
Premier HL-29 LC-OFC Copper Litz headshell leads NIB $15.00
Oak 7” arm tube $8.00
AC motor controller, brand? Suffed board w/schematic $15.00
Tubes
Lot of 240. Most used, a few nib, most small signal, 8 6L6, 18 rectifier, and all test good $120.00 obo
I prefer pick up in SW Michigan, or ship USPS flat rate USA only. See post #19for pdf file.
Gates 833a for display, not working? No way to test $10.00
Caps
Old TRT Wondercap 3uf 425 Vdc (buy yours or sell mine to make pr) $4.00
.012uf 1200v vintage Mica Large chassis mount postage stamp $5.00ea or 2 for $8.00
.001uf 1200V vintage Mica Large chassis mount postage stamp $5.00ea or 3 for $12.00
Sprague Powerlytic 36D 2700uf 300Vdc $10.00ea, 4 for $30.00
National 85 DX 10000uf 50Vdc $5.00
Captron 27uf 700Vac oil Type IIIb LARGE can $10.00ea (2)
Grab bag of vintage postage stamp mica caps. 250V or better, 50 pieces $10.00
Transformers
2.5K/8 ohm 15W 40hz to 18Khz Air gap SE output, brand? $30.00 pr
PK-31 SE OPT 5K/8 ohm 5W $10.00
Custom wound plate chokes, 25W EI core, 27awg wire, air gap, 520 ohm, 54H 60ma HEAVY! $75.00 pr
Raw PC Boards
Superphon SA120 60W/ch amp bds. 15 raw bds w/schematic $5.00ea, $8.00 pr
(used NTE 2382/2383 above, work in this design, plus I may have misc parts)
Other Stuff
35W/Ch Stereo tube amp. Had 7355 output tubes, rewired for EL34. New matched pr EL34 installed, separate bias, ac balance on outside of chassis. PIO caps in signal path. Not pretty but solid, good working amp. Plan to put on ebay for $150.00. Make offer.
Lamda Tube Regulator Model 28 200~325Vdc 100ma 6.3 v 5a. Heavy, a classic $100.00
PS Audio clone line stage in chassis. Works great. $50.00
Pioneer SX60 amp section, 60W/ch mounted on plywood (used a sub amp), works great. $30.00
RCA PR8065 5 disc CD changer $25.00
Iwill KA266 mother board w/ AMD Athlon CPU 1 Ghz, 512 mb, PC100-DDR ram, Radeon 7500 PCI video bd
(CRT-DVI-S Video out) and I/O magic 56K modem. All working $10.00ea or 4 for $30.00
Powork PW450 computer PS 450W $10.00
50+ Western Electric schematics, printed on 11 X 7 paper, unbound, from collectors document. $10.00
Tu-be or not Tu-be. Missing front and back covers, but otherwise intact. A classic! $10.00
Wanted in trade
Pr 3:1 to 5:1 preamp outputs, Edcore XSM15K/600 (anyone try these?), Stancor, etc.
Old TRT Wondercap 3uf 425 Vdc.
Good single coil strat pickups, GFS, Duncan, etc.
10" alnico speaker for guitar amp
Cables
8” pr $16.00
11” pr $22.00
9” pr $9.00
12” pr $24.00
SPK Stuff
SS Parts
ICs
AD711an $3.00ea (4)
AD712an $4.00ea (3)
AD744an $4.00ea (4)
AD811an $5.00ea (4)
AD828an $3.00
MPC SM5813 $15.00
OP176 $3.00ea (2)
OP275 $3.00ea (2)
PCM56p $10.00
SAA7210p $15.00
SAA7220p $15.00
SSM 2141p $3.00
SSM 2142p $3.00
TDA5709 $5.00
Parts
TT Items
Tubes
Caps
Transformers
Raw PC Boards
Other Stuff
Wanted in trade
