1. Check if lens can be moved freely and there magnets are not in friction with lens coil.
2. Make sure your optical ribbon cable make contact. I suggest you to replace this cable.
3. If above do not solve, replace LA6541
Tibi
OK, the lens cannot move freely. There's something blocking them, but I can't see the magnets.
I'm using the model in the picture below, with which I'm not as familiar as with the standard model.
I can see the magnets touching the magnets now. But how to fix this?
What is the timing diagram for signals connected to segment LCD?It could be possible with some buffers and a special matrix OLED.
Tibi
I’m guessing three com signals mux Segment signals S1-S6. But, the digits of LCD are seven segment, how come only S1-S6 signals from LC78601 ?
I’m thinkIng to use a mcu to capture LCD signals, interpret the display information, then create commandS to drive an SPI OLED.
Things are not so simple. ;-)
This was discussed already
Finally, an affordable CD Transport: the Shigaclone story
Tibi
Tibi
I can offer you a Shiga MKII black at 169euro. This include main pcb, display and standard power regulator wiyh 7808.
Not included: cd puck, cd mechanic, IR remote.
I can also offer power supply Zeno with synchronous rectification, bronze cd puck, modded cd mechanic, or a full mounted Shiga MKII high grade Lecel 1, 2, 3.
Ship only to EU.
PM if you are interested.
Tibi
Ship only to EU.
Tibi
This is the best regulator I have used so far for Shiga MKII. A serious upgrade.
Zeno MKII synchronous rectifier ultra low noise regulator.
You may subscribe for one here 3rd group buy for Synchronous Bridge aka Ideal Bridge
Thank you !
Tibi
Thank you !
Tibi
Hi there Tibi!
Got a MKII going/working. I read quite a few pages to about the modes. But I didn't notice anything about the screen light. It is quite bright. There is a place for a 500 trimpot - is that to dim the screen? Shout one of resistors be removed?
Thanks for the super transport!
Tibi,
I have problems. See link.
Shared album - jugi jugi - Google Photos
The transport does this now. Sometimes it has played after doing this, but now only this. There was an actual defect also: one of the wires had broken of. I soldered all the wires strait to the PCB and again it worked for a couple of times, but now only this.
Any idea what to do?
Ok - also a couple of the wires to the main PCB had broken also... I had tried twisting the flat cable to see if there were problems there also, but as there was the heat shrink there I didn't see until I removed the heat shrink. This transport has been stored indoors for a couple of years (since the 100$ deal, you Tibi had at one time). So it if wiered that the cables are in such bad state beside connectors...
I'll solder the the other end of flat cable and we'll see then...
- Digital Source
- Shigaclone MKII Black - The builders Thread
