Seek the replacement of TA3137!
Administrator
Joined 2004
Hi GPE,
Enzo's suggestion should be a good way.
That's true, except that production has stopped on that chip. So supply will get worse over time.
I suggested that you make a small board with an equivalent circuit on it. Design it to plug into the same SIP pinout. Then you can have a steady supply of this thing. Just add the artwork to your master and puch it out with the rest of your product. Or, make a ton of them at once on their own sheet. You could then sell that as a second source for the original chip as well.
-Chris
