Not full range?
Hi Andreas,
The Seas web site specifies the frequency range as 40 to 25,000Hz. That must be full range as we normally understand it .
It shouldn't matter if it is two speakers mounted coaxially or uses a whizzer or dome instead of a discrete tweeter.
What detail am I missing?
Thanks.
Hi Andreas,
Thanks.
The fact that you still need a cross-over to integrate the two drivers (tweeter and woofer part of the coax speaker), so you've still got the problems which come with a cross-over, while a full range with a wizzer cone most of the times can be used without the x-over (with the usual phase shifts) and results in a more coherent speaker.
