Searching pinout 2SC1663/2SA835
<<Then is the layout printed allright in the service manual, but not correct on the pcb.>>
Too bad. I wouldn't be surprised, if you will end up with this pinout: B-C-E.
Collector voltage drop will be less then that of the Emitter junction. And you can follow the traces on the board.
For replacement look for the same grades: Sony grades their parts by digits.
I have discovered the confusing/mix up. The Sony amplifier i am working on is perfectly symmetric built, and so these transistors are mounted, one channel with back and other with frontside to heatsink mounted.
I am searching for the pin order of these transistors. Searched some while on www no result.
Anyone?
SONY 2SA835 can replace through Motorola MPS-U60
SONY 2SC1663 can replace through Motorola MPS-U10
pinout and outline is the same by all types - go to
http://pdf1.alldatasheet.com/datasheet-pdf/view/124196/MOTOROLA/MPS-U10.html
http://pdf1.alldatasheet.com/datasheet-pdf/view/100844/MOTOROLA/MPS-U60.html
This information I read in the same order by follow comparsion table books in German Language
1) ECA "tvt transistoren2 '79/80
2) JAEGER ELEKTRONIK Vergleichstabelle 2001
I am busy with this beast for a year now. 1 fet was burned and 2 drivertransistors and 1 cascaded transistor.
I replaced the cascade transistors to heavier ones, they are the cause of Vfet failure, and want to prevent expensive obsolete Vfet frying again.
All caps are replaced except the big Lytics, all fusible resistors and some diodes/zeners.
So if someone has (a supplier for) Nippon Chemicon 27000uF/80V lytics. :)
Suggestion #1
