Stocker said:I am thinking of a pair of horns for a full-range system in a house with small children who may be intersted in dropping things into the throat of the horn...
Fear of punishment will certainly have a less deleterious effect on the sound than a screen and it will serve a multitude of other purposes later on.
Fear of punishment is, trust me, part of the plan.
But that doesn't change the curious nature of kids! Hey, I wonder what will happen if I drop this little stuffed bunny down the hole in this big box...
If I were to make these, it would be a semi-permanent install due to the hassle of moving them for cleaning... hence the question.
After all, only goes so far.
I would mount that thingie in a way that it could be removed later on (when your kids are old enough to take care).
I don't know how its sonic impact actually is, there will be one for sure but I don't know how much.
But my imagination tells me that it won't be severe since it is placed where velocity is low and pressure is high. If you have a look at professional horn drivers then you will notice that some have fine screens at exactly that place.
Charles
Charles
Isn't the other way around?since it is placed where velocity is low and pressure is high.
Mvg Johan
- Screen in horn mouth?
