Hi i am wondering if this card can work ? Wholesale Free shipping 1pcs/lot 150W*2 TDA7294 BTL & Speakers Protected KIT Audio Amplifier or is it totaly garbage?
I have read that they should not work any good in that setup, is that true?
The transformator i have is 600va 24-0-24VAC
I realy need a fast answer becouse a doing a projeck in school and everything shall be done at week 14.
Manny thanks.
Best regards Axel
Manny thanks.
Best regards Axel
For a school project, it should work.
It helps if it does not work perfectly. That allows you to express your knowledge on how it could be improved if you can use your knowledge to find out "why" it does not work perfectly, thus showing your "understand" the operation.
Even more challenging and useful but time consuming is if it does not work. Finding the error/s and correcting them will really show how much better you are than your peers. But this is a dangerous one. You may run out of time and not find the errors and have to present a non-functioning amplifier with a long dissertation on what you did to check what might be wrong and what steps you took to identify the error/s.
Axel:
AndrewT makes some very good points.
What is the nature of your school project? If you could post the guidelines that your teacher has given for the project- the purpose and how you will be 'marked' on the results, it would help people to give you advice.
If you need to display some basic electronics knowledge, it might be easier if you bought a (DC) power supply module from eBay to use with your transformer. Then you could build a simple amplifier using discrete components (transistors) instead of using a 'chip'. If you are asked to explain the workings of the TDA7294 chip, the answer will be quite complicated.....
Hi i allready have orderd the card now, my intention was from the beggining to make an amp using the tas5630 and make pcb and that sort of stuff, but the time ran out and i needed something to finnish the projeck, but later on i shall finnish the bord so i can learn me some more about it. But now i hope the amp will work,but we will se.
Best regards Axel
Best regards Axel
