Resurrecting this thread: Linearity of LSB
ist the same between TDA1541A and TDA1541.
No given numbers of THD in the 1541non-A
datasheet, but crosstalk between channels
is worse, 80dB only.
This leads to the question how the i2s
datastream can be demultiplexed to
run one tda1541 for each channel individually
but having both dacs inside the 1541 running
parallel? As far as I understand the 1541 accepts
independent channel data (so both internal dacs can
get the same channel data) but the decoder SAA7020
and Digital Filter SAA7220 only provide serial i2s.
From the parallel designs I know (commercial or non
-commercial) TDA1541 are only parralleled the "classical"
way. Did I miss something? Is there a way to demultiplex the
I2s? Looking at SAA7220 datashheet, i2s data gets demultiplexed
inside this digital filter and then remultiplexed again after oversmpling.
Unluckily the filter was not designed to send parallel data
to the DAC...
to the DAC...
Thanks a lot! I think the answer lies in this post # 5010 from ecdesigns:
http://www.diyaudio.com/forums/digi...e-nos-dac-using-tda1541a-501.html#post3917324
