Hey, I was wondering if anyone had access to a diagram or schematic for a Memphis Car Audio 4-Channel Amp 16-MC3004? I only need the values of a few resistors that I'm trying to replace.
The ones I need the actual values for are:
R270
R271
R471
R261
R262
and the big green hand wound resistor? It's in slot:
R267
Thanks for ANY help that can be given on this amp! I was also wondering if I could replace 2 blown IRF540 Transistors with 2 new IRF640 Transistors TEMPORARILY to see if I can get the red protect light to go off:? Thanks
R270
R271
R471
R261
R262
R267
The resistors are likely the same for all corresponding designations in all channels. For example, if R160, 260, 360 and 460 are all the same value, it's likely that you can use the corresponding resistors from the other channels to determine the value of the burned resistors.
