Scan Speak Revelator Adhesive Failure
I'm working on a pair of Sonus Faber Cremonas and thought one of the midrange drivers, Scan Speak 15W Revelator, was blown because of the kazoo type sound it was making, especially audible on piano. When I pulled the driver the exposed portion of the voicecoil looked fine and there was no rubbing. I ran a 440 tone through it and it soon became apparent that the glue holding one of the cone slits together had failed, and that the slit itself was buzzing. The surround was also starting to become unglued at a point connected to the slit opening. I repaired the problem with adhesive and the driver works fine now. I decided to test the "good" speaker as well and found it to be bad as well, with the identical failure mode, although not as far along or audible as the first driver.
The speakers are around ten years old and have been used in a house at fairly extreme elevation, around 9,000 feet, so the low humidity that comes with high elevation might be a factor, but I really think this constitutes a pretty major design flaw. Drivers shouldn't just fall apart after ten years, even poly foam lasts longer than that. The woofers use the same technology, so I wonder when they will start falling apart. Sonus Faber wont help me on this as they are way beyond warranty, and of course "this is the first they've heard of it."
Have you contacted SS?
I will try on Monday. Here's what's happening:
attachment.php
I've got a pair of 15W Revelators in my 'Intimates' speakers so have a keen interest in your situation. Mine are only 2 yrs old though.
It looks to me like you have a couple of repair options (assuming things with SS don't work out). Find some moderate viscosity black rubber cement you can dispense with a fine tipped applicator and re-seal that exposed section of the slit. You'll also be able to use that stuff to re-seal any portion of the rubber surround as well. Maybe SS will sell you a small applicator bottle of exactly what they use.
The other option is to cut a small patch if light weight porous fabric (scrim?) and glue it to the back side of the cone whilst pushing up on the seam to close it up to it's original width.
The small waves along the surround edge suggest there's some expansion and/or contraction occurring there. That could be what's causing the edge of the cone slits to fail.
Maybe the dry air has caused the edge adhesive to shrink, or something had been applied to the surround that's caused it to swell. Some rubber conditioners and cleaners can do this to woofer surrounds.
From the photo can't tell the material of degraded rib.
I have found the out gassing of some synthetic carpet can turn certain plastics to mush (the belts used in turntables and tape machines), do you have any synthetic carpets or other plastics in proximity to the speakers?
The air couldn't be purer than where these have been, and there is nothing like what you are describing in the home.
Nothing has been applied to the surrounds.
I still haven't heard back from Scan-Speak. I don't speak Danish, and when I call all I get is a nice music loop and a message in Danish that keeps just repeating itself. Customer service sure isn't what it used to be in the luxury goods market.
There is a glue for repairing the seal around car windscreens. I have used it to repair small tears in speaker cones and found it nearly ideal. No sign of any problems after 10+ years. It is black, non-hardening, comes in a tube with a narrow nozzle applicator. Similar to
Windscreen Sealant Window Sunroof Cluster Leak Light Repair Sealer Black | eBay
The link doesn't work. I searched *bay and found it. It seems all of the sealants come from the UK? I pasted the URL here but it didn't work either so deleted it. Just do a search on *bay for those key words and it does come up.
well, something looks weird with that driver
but I suppose Sonus Faber is only using genuine ScanSpeak
Nothing weird about the driver except that it's coming apart at the seams.
An email to scanspeak might work...
info@scan-speak.dk
It didn't. They told me to contact SF. SF had already told me to pound sand and constact Scan-Speak.
Another suggestion. Contact Adam at Madisound. They are the U.S. distributor of SS drivers. They may be aware of your issue or even have some of that slit adhesive.
I'm pretty sure they will answer the phone. Ask for Adam. He's a nice guy. If anybody can help, he can.
I've been working with Adam. He is a great guy but only offered to supply replacements, and said they were unrerpairable.
Aleen's did the job!
You wouldn't want or need butyle rubber for that.
My old Revelators looked like the slits were glued with rubberized CA glue...most speakers are assembled with CA glue anyways.
Butyl rubber is not an adhesive. What is CA?
To make a very long story short, I convinced SF to replace the drivers. I would suggest to other older Revelator owners to test their mids with a 440 Hz or so tone to see if they are on their way out. They can look perfect and sound OK with music while putting out shockingly high distortion.
