I just had a look at the drawings. The straws are put in the (bass-reflex) port.
What are straws? Straws are used to drink your lemonade right out of the bottle... (Drinking) Straws... Amazing...
I have two kids so I know drinking-straws are sold in at least 2 sizes (diameter that is).
It's nice weather today... I think I'll go outside and drink another bottle of Coke with a ....
Jan
Jan
Banned
Joined 2002
Tech notes
Alas, a published reference. The scanner will work someday, http://www.diyaudio.com/forums/images/icons/icon9.gif
Unhappy
I have built the CABS out of 1" MDF, with a 1.25" baffle. These are heavy, and secure, really a nice size.
Unhappy
I'm BACK!!!
Hi to everyone,
As promised I am back after my wedding. I have started building my cabinets. I am using two panels of 19mm MDF glued together for each cabinet side. I have already made the circular openings for the units with my router. At the moment I am gathering the sound damping material. As soon as possible I will post some pictures.
George
Hi to everyone,
George
Hi-
I am interested in building the Reference Plus, but I am not fond of the idea of using a ported enclosure. I have a feeling that I can not simply modify the design and not use a port, but keep the box sealed. Maybe I can simply modify the internal volume.... What do you guys think?
Taco said:The ported design is very good, simply changing the cabinet isn't a good idea.
Ported it is then. What about placing the port at the front of the cabinet? Will this effect the design significantly?
Years ago I purchased a pair of D2905/9900 Revelators and a pair of 18W/8545 woofers. I have long-since lost the crossover design I had intended to use. The Reference Monitor seems to be an ideal speaker for these drivers, but it uses a 18W/8546 woofer.
I'd be interested if anyone could inform me as to what changes to the crossover I need to implement in order to use the 8545 for this speaker design? The only other speaker I've been able to find on the net using these drivers is at:
http://www.audiocostruzioni.com/a_d/diffusori/scan-revelator/scan-revelator.htm
Any other suggestions?
- Scan-Speak Reference Monitor
