I searched and read a lot and not only the forum.
What I didn't understand is if any PWM controller can be fitted to the rest of the SAPS-400.
And what about the feedback loop.
I'm new to SMPS, still learning theory and reading as much as I can, sorry if I wrote something stupid.
I just wanted an example to see how it can be connected and what are the parameters.
Enrico
Enrico
Hi
The only problem is that this smps is a selling unit, they can't give you everything, and control board is more important then main board. I don't know what did they used but you could use any, again it all depends on what they have. Some with feedback. There are many ways to do both parts (control and feedback), but any of them could be used, so not much help i'm affreid
enrico,
I'm going to dump the variable voltage feature, I know its nice, but very bad for control loop(I want a relatively fast psu). Do you know what your voltage requirements are? I might look to see if I can accomodate you. I think I am going to make it 65-0-65 for now.
Enrico, I haven't gotten around to doing the maths for this one, but take a look here:
http://www.diyaudio.com/forums/showthread.php?threadid=56589
It might be better suited to your needs, as well as higher power handling.
- More Vendors...
- Elektor
- Saps-400
