Updated my order to three boards.
Please Update the list yourselves when you type here:
1. wendell c : 3 set : 48
2. andRookie : 3 set : 34
3. df_genius : 4 set : 64
3. sandbasser : 4 set : 64
5. daanve : 2 set : 34
6. barmanekm: 1 set : 18
7. ksnider1: 2 set : 34
8. mace1337: 2 set : 34
9. CeeVee: 3 set : 48
10. merlin el mago: 2 set : 34
11. Westley : 4 set : 64
12. Groundloops: 4 set : 64
13. Ciu : 4 set : 64
14. fitzfish : 4 set : 64
15. ClaveFremen : 2 set : 34
16. Ramallo : 1 set : 18
17. number9: 2 set : 34
18. frozen wing 2 set :34
Total GB : 49 set (minimum order must be 50)
2. andRookie : 3 set : 48
Total GB : 49 set (minimum order must be 50)[/QUOTE]
8. mace1337: 3 set : 48
Total GB : 50 set (minimum order must be 50)
Updated my order to three sets. Minimum reached yay!
quanghao -
I'm a little confused by the picture in post 12 which shows c8 as 22uf or 220uf and the schematic in post 13 which show it as 47uf. Can you please clarify???
Thanks,
C8 depends wich voltage you need, seems 22uF/100V till 35V, 47uF/6.3V for 3 or 5V, I suppose 220uF/100V it's a typo.
Mine Hypnotyze boards & mine Salas low voltage regs V1.0 with remote sense use 100uF.
I'm in for 3 sets
19. bracla: 3 set : 48
Total GB : 53 set (minimum order must be 50)
1 set for me too please!
20. Globulator: 1 set : $18
Total GB : 54 set (minimum order must be 50)
I take 2 sets
21. korben69 : 2 set : 34
Total GB : 56 set (minimum order must be 50)
Thanks Merlin for updating for me the list
I'll take 4 sets
22. analogdiy : 4 set : $64
Total GB : 60 set (minimum order must be 50)
I would like one set
I'll take 1 set
23. rickmcinnis : 1 set: $18.00
Total GB : 61 sets (minimum order must be 50)
I'll take 1 set
Your welcome, most imporatn thing is you don't lost the PCB
Ciao
@quanghao
Please could you include remote sensing in the boards, will be better than cutting tracks?
I'll take 3 sets
24. guglielmope : 3 set: $48.00
Total GB : 64 sets (minimum order must be 50)
I'll take 3 sets
Hi
One set for me,please
Marco
24. suburra : 1 set : $ 18.00
Total GB : 62 sets (minimum order must be 50)
__________________
Marco
__________________
25. suburra : 1 set : $ 18.00
Please pay attention when update the list, thank you in advance.
Hi
Just come across this GB and am very interested in participating. The output is specified as 3V to 35V - what is the maximum power the supply can output, say at 35V?
Changing some parts & mosfets with proper heatsinks I am going with the Salas Low Voltage regulators from 1.5V till 46V, the current is fixed with R1.
quanghao -
Thanks,
Hi!
If you use 22uF-47uF/MKP
Or use 220uF, the cap is not MKP.
@quanghao
Well, I can do as you say, you can just add me that will arrange the stars??
Have you any comments about the layout please give me any suggestions, to layout the best!
Quanghao Always look forward to your help, Thanks!
PM: merlin el mago!
Is this the image that you want me to do? would be further clarified
- Group Buys
- Salas low shunt Group-design by Salas
