Salas hotrodded blue DCB1 build
Finished my DCB1, need to cut a heatsink for both sides of shunt. Here is where I am at with the build. I decided to install the PRP and upgrade in the future, I'm gonna see how these sound!
diyAudio Chief Moderator
Joined 2002
Congratulations to you both. Soon to know your impressions.
P.S. Wendell, I wonder what is the colour when those different leds combine? Would like to see it lit up when sinked and powered.
P.S.2 (not the game machine). If those CCS setting resistors are 8K2 and not 8R2, there will be no lights.
Joined 2002
I see, its a pentode anode CCS loaded triode. Not a DRD choke amp. The trick is to have enough output from the I/V so its able to fully drive the amp in peaks when with a unity gain pre. Should also have a bit more gain than average 300B due to the 6H30Π being CCSed.
difool, I was going to use a 90 degree angled screwdriver.
Salas, I was thinking about that also and planting it on its side to save space in chassis layout but was not sure if the sink was big enough. Hot Rod versions is described as burning, I don't want to use fan as I've seen on some other builds.
