Rozenblit's amps
diyAudio Senior Member
Joined 2002
A fellow member was kind enough to point to an error I made back in post # 6.
The 6C19-Pi is kind of half a 6AS7G.
This in not true and also incomplete.
So, in case anyone plans to build with the 6C19-Pi it would not advisable to take a good look at the datasheet of this particular tube.
I apologise for giving you all the wrong information.
Cheers,;)
OK.. if anyone have it and would like to share it with me, i'd be gracious if someone sent it to: spamfilter at cactuz dot org. I will not redistribute it.
Edit: Just had a look at the patent.. http://www.audiodesignguide.com/otl/5604461_tif_1_s0_35_r0.gif. The circuit described seems very similar to what I'd assume the T8 25W should look like.. is it in fact the same circuit? (no PSU ofcourse)
