I'm currently recapping the amp which had been partially restored before. There are three blue electrolytic capacitors that I can't find the values for as the writing has worn off and I can't find them on the schematics for the separate pre/power version. They look to be small uf and voltage values and might have been replaced before.
Does anybody know what the values are for
The capacitor that is on the balance control
2 identical small capacitors that are just behind the push selector switches
If anybody has replaced the 6.8pf capacitors between the pins on the 2 output valves what type and voltage value did you use.
Thanks in advance to anybody who can help
Just in case anyboy needs theis information. I've got hold of another Cadet amp and the values of the capacitors in it are
The capacitor that is on the balance control - 125uf 4 volt
The 2 identical small capacitors that are just behind the push selector switches - 50uf 3 volt
