I happened to notice that on pin 7, not sure how to word this. The ground when, I tested pin 7 made like a spark noise on the ground from the tester? Noticeable when on the pin s and then off.?
An audible current sound from the ground point. Like a a spark just low current sound. It very strange. Does the final pin look readings look normal, to you?
