You need to determine why you don't have negative 15v on pin 4 of the op-amps. Check the LM337.
I replaced lm 339 with no difference still have 4.5 vdc on all of the op-amps pin 4's and full rail voltage on speaker terminal, R206 and R306 have 4.5 vdc as well just not sure where to go next. I seem to be better at major repairs than little stuff like this. Any suggestions?
Perry replaced both LM337 and LM317 and the rail voltage is gone on the terminals. That would explain why I had + rail voltage on one side and - rail voltage on the other side. Both were burnt black inside upon popping them apart. What would cause both of these to go out. Someone reversing polarity on power supply? I am going to test for sound now................TTYS
- General Interest
- Car Audio
- Rockford Punch 800a2
