Did you check to see if any of the source resistors were out of tolerance?
Did you check the smd trasistors marked 1A and 2A?
Did you check the smd diodes marked 5D and A7?
Also did you check the SMD resistors within the channel that was blown to see if any are out of tolerance?
The source resistors are the large resistors connected directly to the source leg or each of the output transistors.
The SMD resistors are the tiny surface mount resistors used throughout the amp (like the gate resistors).
The other SMD components he mentioned will have the markings he listed on the face of each of the components. All will have 3 terminals and a black body.
Finally got round to trying a few of your suggestions on this one today.
5D was showing a dead short on all 3 pins so I replaced it and this amp is now fully operational! Sounds very good.
Good day on the Rockfords, got 2 working today.
Thanks gents for all your suggestions and support.
- General Interest
- Car Audio
- Rockford Punch 200.2 one channel down?
