Perry...... I have found a mistake I have made, I forgot or missed to solder one of the legs of the new transformer I soldered on the board. I soldered it re-installed R316 and the amp produces clean audio on the scope.
I am going to clamp it down and re-test to ensure the problem is solved.
I should have caught that something was wrong when the one 3706 IC had a different voltage reading on pin 1 of U410......BRB!!!!
Problem WAS solved......I resoldered resistor and powered up the amp and produced clean audio and all was good. I removed the output board to put thermal grease down and forgot to disconnect the power.
Re-installed output board and was hooking up red/blue/white wires and when I hooked up the red wire HUGE spark and now amp wont power up does nothing but squeels really loud, so I unhooked output board to see if the problem was there but no.....still same issue.....none of the p/s fets test shorted but amp will not power up now.
I dont know what I have done here any ideas????
Pins 13 and 16 on the 3526 have a perfect square wave as well as all the p/s fets gate legs. I dertermined this with just ground and remote hooked up.
Upon trying to power the amp it squeels loudly and draws about 20 amps then subsides to about 15 amps but I only leave power to it for a few seconds because I dont want to pop anything.
The voltage across the red and blue wires is about 84 vdc while powering the amp, I just stuck a lead from my meter into each wire and tried to power to get a reading. The rail caps are 160V caps so the answer to this question would be no.
This is very frustrating the amp was working great.....but still seemed to struggle a bit powering up. I think there is a fault some where in the power supply, but I believe the output section to be fixed.
The schematic is a little confusing to me I was trying to see what the red wire was tied in with from the power supply side but they show it in like 3 different spots on the schematic and I cant tell which is what. I saw one spot where it was tied in with some small transistors maybe blew those?
What do you think?
What do you think?
- General Interest
- Car Audio
- Rockford Fosgate T30001
