WTF? So this is a BJT based power supply? Wow that's weird I thinking these were mosfets. I'm glad I know now I was about stick in IRF3205s ha ha.
Anyway a output burnt up so that's what made pop noise so I removed it and now the amp will turn on but the LED is very dim.
Also is the tab of the drivers for the power supply transistors connected to the middle leg of the transistor? D40D8? I removed the ps transistors and metered them and they tested fine but not sure on the drivers?
Hmm when I probed the center legs of the drivers I got a reading of .539 ohms and the other had no resistance I even probed the center legs to the center leg of the power supply transistor and got some resistance. I just want to find out why it's turns on but very dim. I have mpsa06 in TO-92 case will that one work?
I don't think it's anything with the drivers or the power supply transistors. I think something else fried and I can't find what's not allowing the amp to turn on. I've checked the ps transistors so many times and everything else in the power supply side. I need some help with this...
- General Interest
- Car Audio
- Rockford fosgate punch 45 no output
