Rockford Fosgate Power 800.4
I thought that you had -37 with Q105 and Q106 out of the circuit (post #18).
I assumed that the voltage on the base of Q122 was at or below the voltage on the base of Q121. If that was so, the transistor would have to be open if you read 40 ohms between the gate of Q110 and the emitters of the drivers. The base of the PNP driver can't be that far below the emitter unless it's defective.
A pic of section I am working on.
When I recieved the amp there was a jumper wire from the circled areas which allowed Q110 and Q123 to read the same resistance as the rest of the outputs gate to source. The voltage was still present though.
The jumper was shorting the drive voltage to the drivers.
Leave Q105 and Q106 out of the circuit.
When you had 50v, if you touched a dummy load to the speaker terminals, would the amp draw excessive current?
clamp the outputs before trying this.
Do you have any new RCA jacks for the amps like the T20001BD?
Or do you know what they cost from Rockford?
I dont get this amp, with Q105 and Q106 out of the circuit I no longer have the 50vdc I have the -37 again. Maybe Q122 is defective again. It reads -4.49 on the emitter and -.966 on the base with Q105 and Q106 out of the circuit.
When I try to hook up a dummy load the amp draws massive current like it has a dead short.
I do not have any new RCA's for that series. I dont know what Rockford charges for them, but I have several used sets that are perfectly fine.
Do you need a set? Just one or both?
OK. With Q105/6 out of the circuit, give me the DC voltage on all terminals of Q121, 122, 110, 123. Place the black probe on the negative rail or the source of Q110/123.
Confirm that Q121 is an NPN transistor and Q122 is a PNP transistor. Also confirm that Q110 and Q123 are IRF540s.
I need to order new ones to justify the labor that I'm going to have to charge. I'll check with Rockford.
Q110 and Q123 are IRF540's (YES)
Q121 is an NPN (YES)
Q122 is a PNP (YES)
Holding black probe on source of Q110 terminals of Q121 and Q122 read as follows:
Q121
C: 23.18 vdc
B: 1.775 vdc
E: 22.92 vdc
Q122
C: 2.530 vdc
B: 2.545 vdc
E: 22.93 vdc
When checking Q110 and Q123 can the black probe be on the amp ground?
