Rockford Fosgate Pinch 400.4
Dont completly understand post #19
Im going to use my sine wave generator with a 100hz signal and set the level so i see about a half volt of AC on the op-amps..
The op-amps are U100,200,300,400,101,103,301,401
Which ones do you need the Ac volts on ??
For example U101 all pins or which pins are you refering to since there is a total of 16 pins you want the voltages from ?
Voltage at RCA Jacks is 1.896 with black probe on Amps ground terminal..
Crossover set to full range gain fully clockwise..
Pin 1:0.814
Pin 2:0.820
Pin 3:1.794
Pin 4:1.795
Pin 5:0.820
Pin 6:2.993
Pin 7:0.821
Pin 8:0.820
Pin 9:0.823
Pin 10:0.825
Pin 11:4.01
Pin 12:4.17
Pin 13:0.833
Pin 14:0.820
Pin 15:4.01
Pin 16:4.14
I will look at the preamp section more closely and to see if i can find the bad connecions..
Owner just called and said i can take my time with the amp since hes dealing with a money issue right now..
So i will put this one aside for a couple of days and then look for bad connections on th board..
Thanks or your help so far greatly appericated
