That means the DC voltage is -2.8v.
Post the DC voltage on the outputs again (gate to source, black probe on source).
If you connect a speaker across the speaker terminals does the current draw increase any?
Check the two transistors that are out of this channel. Do either appear to be defective?
I am a little confused on which channel has the problem after reading this post. If the left channel is the problem.....................
Check R262,R263,R234,R235, and see if they are within tolerance. If they are they should read at or close to 20 ohms. If these resistors are out of tolerance they can produce a generous amount of DC on the channel.
this amp have 35v at one of the speaker terminal, no shorted
output or drivers. voltage at the tl072 pin 8 is +14 volts
and pin 4 +6 volts instead of -14. any suggestion?
Megael9 check the LM337 negative voltage regulator and see what it reads for pins 1,2, and 3.
- General Interest
- Car Audio
- Rockford Fosgate 800a2
