Rockford Fosgate 1500-1bd (2007)
What I meant perry is it only is working normal without the two transistors that we're heating up so there is an issue with those two mosfets. With the other transistors still in At leg 1 I have -89.6vdc and leg2 0vdc leg 3 -91.4vdc. so there must be a problem on the output driver boards somewhere. Would I need to remove all the output transistors and check for drive again on those two locations?
