Old design but I have a few 807's in the shed
How critical is the 6k primary on the OPT's ??? Edcor do the CXSE25-8-6.5K (EDCOR - CXSE25-8-6.5K) would this be close enough??
What have other DIYers used??
Cheers
Cheers
It is not that critical. For 6L6 (which 807 also is) the recommended load resistance varies from 2k5 to 6k.
The plate voltage with 6k5 should be some 450 V to get optimum results.
Then the screen voltage should be limited to 200...250 V.
If only some 300 V is available as +Ub, then the load resistance should not be more than 4k5.
B+ is likely to be just under the 350v in the design.
Will look at this one,
15W, single ended tube output transformer for 3.5K Ohms to 8 Ohms.
GXSE15-8-3.5K
EDCOR - GXSE15-8-3.5K
GXSE15-8-3.5K
- Tubes / Valves
- RH807 output transformer....what did you use?
