Hey All,
I've built two RH84's and really like the sound. I ran across a thread on DIY Tube about an RH6550. It doesn't seem to be on the RH website though. I've attached a schematic. Has anyone heard anything about this amp? Or built one? Does it sound as good as the RH84? The thread states its about a ten watt amp does that sound right?
Kevin
Kevin
Yesterday I completed an "RH-KT120". Worked fine in my test setup. When I moved it to my main system..I had created a short somewhere and a fuse blew. But this week I'll let you know from my point of view if it is worth it going to a bigger tube with this design. Initial thoughts though: Different rather than better.
I think you are referring to the chokes The chokes are by Sound Carrier and are type C3. Multi-sectioned.That is a pretty build Nice output transformers etc any more info ?
The output transformers are tucked under the chassis. Psu transformers and chokes received a hum band from me. Not sure if it is effective. (Amp is quiet but perhaps it would have been as quiet without them)
Power transformers are paralled and hybrid graetz bridge for 700vac. Choke input psu. (Power supply is mono)
Outputs are probably "underpowered" 78usd a pair including shipping supplied by Twin Audio (In Manufacturers sub forum).
Your wish is my command.need a peak underneath ........
Did you get this working? and sort out the problem.
I noticed this,
RH Amplifiers: RH Universal v.2 – Totally Universal
M. Gregg
- Tubes / Valves
- RH6550
