RF Punch 250a2 output Transistor?
OK let me first start off by saying that I'm a NOOB to this site and to the internal workings of car audio amplification. Ive Been playing with Car Audio for 20+yrs now but never got into the internal workings and I'm very interested in learning. Ive been reading/Studying BCAE Basic amplifier repair tutorial over and over to suck up every last detail i can but as i said I'm very fresh to this Subject so please bear with me and what will probably be some dumb Questions. Okay so now on to my questions. I have a RF 250a2 that I've had since new in 99. The Right channel hasn't worked in years. The 2 output Transistors on the Right channel are dead. Zero Voltage on the center leg. (33V on the left outputs). I'm looking up parts to replace them and the Transistors say IRF540 and IRF9540 on them. when i look on Mouser.com there's a bunch of different options for the IRF540. Some Just say IRF540 but theres also 540PBF or 540NPBF, and also some other with letters following the IRF540 with the TO-220-3 case. They all seem to have the same 100V rating but some Have 28A and some are 33A or 36A options. Can i use any amp rating as long as there all matched? Are more Amps better or able to handle more load? I plan on replacing the Left side too so it will be as balanced/equal as possible . Also why are the 2 ouput transistors 2 different #'s IRF9540 and 540. Sorry for being so long But i do appreciate any Advice. Thanks in advance.
Yes.. I just tested again and got -31V on the 9540 and +31V on 540. I brought home my Fluke DVOM from work tonight to compare to my chepo craftsman at home and it was 2v less but.. Not sure why but i trust my Fluke over any other brand. Also i hooked up a speaker just for the heck of it and it has amazingly clean clear sound on that channel.
Also is there a particular brand that is more superior than one another. I see International and Vishay available in what i need. Someone told me that Fairchild is kind of a cheaper less than middle grade brand. Don't know how much truth there is in that but i Would like to have this amp last as long as i can.
Here's 2 that I had on my phone
OK.. well even though i still dont see the burned source resistor ( sure your eye is better than mine) there is one odd or different reading. the 2 source resistors on the good channel read 000.5ohm .. the bad channel N channel fet resistor also reads 000.5ohm but the P channel resistor is all over the board but settled around 0.730k ohm. dont know what resistance is suppose to be but that one sure sticks out like a sore thumb.
